engine gearbox conversion help urgent
luke06
im jus wonderin will the gearbox off my 90 boxshap civic 1.5 fit my 94 esi engine :confused:
It will bolt up, yes. What chassis is it going into though? They switched from cable-actuated to hydraulic transmissions with the start of the 92-95 body style, so if the 90 transmission is going into the 94 chassis then you'll need to do some converting. If the 94 engine is going into the 90 chassis however, then you'll be fine...
thanks very much for the reply..
is thir any way you can direct me to a post on the90 civic esi conversion or somtin simelr cos im only new to the whole ting... thanks
Wait a minute, what engine came in the ESI? As long as they're both D-series engines you interchange transmissions. If you're wanting to put a B-series in it though, then that's not going to work. You would need a B-series transmission...
i dont now if its d series cos i havin cos i havin got the car..
can u tell me the chassi num by any chance of the esi engine... thanks
