FearTheTruth34
b16 port matched head
stock intake manifold
stock b16 cams
b18a1 block rehoned serial number 3323325
ctr pistons
stock ls rods
gsr water pump
gsr timing belt
arp rod bolts
golden eagle head studs
6 an anodized oil line
paint stripped valve cover
gsr dizzy is included
oil pan included, with oil girdle from the ls, with oil pickup
stock replacement exedy clutch and pressure plate
setup will yield 12:1 compression, cams will work on the setup but lack or lift and duration will rob you of power. setup would like skunk2 pro 1s or some ctrs at the very least. with stock cams id expect the power to be about 180 whp, as i have seen p30s with b16 cams making 175 whp.
ImageShack - Hosting :: mant001by0.jpg
ImageShack - Hosting :: mant007lc4.jpg
ImageShack - Hosting :: mant003lm9.jpg
ImageShack - Hosting :: mant009oy4.jpg
$900.00 NO TRADES!!!!! Its worth well over this amount, i put about two grand into this build.
stock b16 cams
ctr pistons
stock ls rods
gsr water pump
gsr timing belt
arp rod bolts
