TravisCadello
Banned
none of my windows work at all i checked all the fuses and their all good. i dont understand whatelse could be wrong any help would help. thanks!
I had a switch that went bad. Took the door apart and the motor for the windo out. Hooked it up to a lanter batter and the motor worked. Replaced the switch, $10 off ebay, and it's good as new.You stated that you checked all your fuses. What about your relay for the windows? Also. it could be the window switch on your door panel. Did you have your window down and it rained and got your window switch wet?
Motors?
