Knock Sensor
4drteg54321
Block:
LS B18A1
OK i forgot to drill a place for a knock sensor when i had the motor out if there another spot i can put it??
i got a ? i got a 94 prelude im doing a motor swap h22 can i take the motor out without the tranny. i dont wont to take both out
Because Ls block didnt come with one and my ECU throwing a code for it
There's really nothing you can do at this point except to get your ecu chipped and disable the knock sensor. You can also try grounding out the wire for the knock sensor. Sometimes though, this method works, sometimes it doesn't. It's worth the shot I suppose.
What ECU are you running? A PR4?
PR4's don't look for knock sensors so my guess is he's running a B16 or GSR ecu.
Start your own fucking thread. I could answer your question but if you're too lazy to even start your own thread, you don't deserve an answer...
How you start your thread
Did you even read the list of rules and FAQ provided when you signed up or did you just click' I agree' and think your ass already knew everything? jesus fucking christ, what the fuck is wrong with people these days not wanting to at least TRY and figure shit out on their own?
Here: HondaSwap Forums - FAQ: Board FAQ
If this happens again, a mod or admin will surely give your ass a vacation for threadjacking...
Sorry to the OP... back on topic...
Don't hold back man. Tell us what's really on your mind.
Put 'em in their place.
lol. I mean seriously, how hard is it to at least try to figure it out. It's obvious he didn't try because it's so fucking easy to figure out.
It's easier to have someone wipe your ass than it is to do it yourself. Some people have that gentle touch and wipe it with soft, moist towelettes. Guess that's what he is looking for. Too bad he got the sandpaper to the pooper hole.
well there 2 wire on the knock sensor plug which one do i ground?? BTW i have a GSR ECU. I been searching but i havnt found a way to ground it.
the knock is only a one wire sensor so i assume you just pulled a plug that fits, off of another harness. ground both wires coming from the plug.
yup i guess it was one wire i had it pluged somewhere esle. i grounded my knock sensor and sometime it the check light come on and off, but my car feel like it running way better.
