need help with radiator fan.....
podagee
my 93' del sol si radiator fan doesnt turn on...i rigged my own switch and lines to the fan but it gets lame flipping up and down so often.dont want to cut the wires cause i dont want to mess the harness up.doe s anyone know the wiring if it needs to be spliced)or the switches and there locations.
i thought you already ran it to a switch
i like em be back to stock cause its irritating flipping the switch.i want it on only when its supposed to be on.
should be toward the back of the block kinda at the bottom you will see it going to where fluid travels through
