crank shaft pulley issues
ok heres my problem.i had a D16A6 block built that i pulled out of a 88 CRX Si i put a VTEC head that i built on it and some where in the build process the crank shaft pulley for the [COLOR=blue ! important][COLOR=blue ! important]timing [COLOR=blue ! important]belt[/COLOR][/COLOR][/COLOR] went missing.
in the process of trying to find a new one i found out that there are two different size crank shaft timing belt pulleys for that year D series motor a a bigger size and a smaller size, i need the smaller size and i went to honda and found out that the smaller pulley has been discontinued. i have called every parts place junk yard and [COLOR=blue ! important][COLOR=blue ! important]dealership[/COLOR][/COLOR] i could and no one has the pulley.
does some one out there have the pulley i need im desprate... i put about $3000 into the block to get it balanced bored and all the parts to put it together
any help would would be awesome!!!!
ok heres my problem.i had a D16A6 block built that i pulled out of a 88 CRX Si i put a VTEC head that i built on it and some where in the build process the crank shaft pulley for the [COLOR=blue ! important][COLOR=blue ! important]timing [COLOR=blue ! important]belt[/color][/color][/color] went missing.
in the process of trying to find a new one i found out that there are two different size crank shaft timing belt pulleys for that year D series motor a a bigger size and a smaller size, i need the smaller size and i went to honda and found out that the smaller pulley has been discontinued. i have called every parts place junk yard and [COLOR=blue ! important][COLOR=blue ! important]dealership[/color][/color] i could and no one has the pulley.
research and see if any other engines used the same part or on that is the same specification as it, thats all i can think of
its actually the crank gear. but ive looked threw every parts catalog that honda has at the dealer ship and so dar have found nothing that fits. i dont know why honda made two different sizes but no one seems to have the gear i need...
yeah but the problem is most of throw the older stuff away. and if they do have them they're in socal and i live about 6 hours north of la where most of them are
so its a d16a6.. and you need the crank drive gear for the timing belt correct? and honda has discontinued it? damn....try this website MAJESTIC HONDA.COM
