well the bseries blocks are good until 300hp..so you will need to sleeve if you want to hit around 300..but any turbod bseries will get you the power if you have the money,
As long as you keep up on the maintenance, and it's built and tuned right, it should run reliably. There really isn't any way to say for sure how long it will last.
As for the best motor to drop in there, it all depends on what chassis it's going in and how much you ultimately want to spend...
