lostinmiself
That Guy....
Background:
I have a D16a6, in a 1990 Hatch Si. I was going about 115, and the tack started to drop. Now i can get the car to trun over fine, but it will not start. It some times will start for a brief moment, but immedeatly die. I have changet the plugs, wires, fixed the timing, checked for fuel pressure. I have taken out the injectors, and cleaned them as best that i could. I am going to put them back in tonight. Next i plan to see if it is the fuel pump by having a friend trun the car on acc. while i listen by the fuel door. After those two things i have no idea what to do. I have looked at the ECU when i turn the car to the III before starting, but it only flashes once (letting me know it is on) so im not sure where to go from here. If you have any ideas please let me know.
