you should be able to keep your motor mounts and if you want you could actually swap the heads and intake manifold and you would have 210hp with the f22 compression ratio so you could boost your car
so the H22A1 doesnt produce 210 horsepower?
and the compression ratio of the F22 isnt better for boosting? wow so you really think this isnt legit advice?
ok well go be a freaking jerk and give someone else bad rep and call them a tool ok?
so the H22A1 doesnt produce 210 horsepower? and the compression ratio of the F22 isnt better for boosting? wow so you really think this isnt legit advice? ok well go be a freaking jerk and give someone else bad rep and call them a tool ok?
Gosh brutal you sure made him mad lol
I have a 97 accord lx with the f22b2 non vtec and obd, and i got a JDM H22A OBD1 DOHC VTEC ENGINE, 5 SPEED TRANSMISSION OUT OF A 92-95 HONDA PRELUDE. what do i have to do to do this swap, and can i keep my f22 engine mounts, and also is the obd 2 to 1 going to be a problem.
my mistake on the A1 i was lead to believe that it produced 210 hp but i think that was the A6. as to the compression it changes a little but it stays the same. i have a friend who built a hybrid for his 94 accord ex and with subtle mods he was able to dyno 213hp. however he had forged internals and aftermarket cams.
