none. youd have to get a sohc vtec head
what do u mean by some work what will i have to do i was told a f23 would bolt up with no work help plz thanks
all i would need is a vtec ecu and the silonoid i do belive if im wrong correct me thanks
so will an h22 head actually bolt on to a f22a blockk? i was wondering that myself i wanted to put an h22 head ont the f22a block in my preludebeside wiring and ecu will it bolt on?
Try this first....F22a6 camshaft, H23 intake manifold, S2k throttle body, F22a4 header or aftermarket header. Exhaust and Intake. If its a five speed you can try either a H22 or H23 transmission, both have tighter gears than the accord. H22 being the tightest geared of the two. A Prelude ECU or accord Ex ECU can be used to run the IAB's in the intake manifold. That should be a good start for you.
