timing issue
shahzzy
noob
So I got TDC lines up and everything, I i figure out I have a bent valve from b4 when I tried to start it over with timing off =[
new motor, might as well not fix it and just wait for the motor swap?
hom much $$ aprox to fix this shit?
or am i better off with a new motorlater on?
I am at the moment, and why are you such a dick? I didn't ask for alternative ride options, I asked for opinions on repair or replace.
If you've got a TL to drive, fuck it.. wait till you have the money for a swap
Dude, you can easily fix that, go to Autozone or the like, get some JB weld, remove oil cap, empty both tubes, crank it on and off for about 3 minutes, this will mix the JB and move it to where it needs to go, let sit overnight and youll be good as new in the morning.
