Is there a difference between these two distributors except perhaps for connections? Autozone lists a different part number for auto/manual and im trying to figure out what i need to change to make one work for the other. Is it most likely just connectors?
The connectors are the same for both the one you need is stamped on the casing TD-18U but TD-02U is also compatible so to answer your question yes you can use either one.
