d16y8 to a gsr
94civic_si
ok i have a hook up from a friend. he has gsr that he dont use.
so i want to know if it would be a hassle to swap it in my d16y8 1994 civic si (eg).
search search search. you need to go to www.hmotorsonline.com and look for a complete swap. depending upon what you get u might need axles. motor and tranny mounts, shift linkage, and ecu if not of that comes with it.
He doesn't neeed to go on hmotors or anything, his friend already has the motor.
Pretty much just look up "B-series" swap. It's a very easy swap and bolts in using the correct components(pretty much just Integra stuff).
Also, was the motor swapped? 92-95 Si's came with D16Z6s, And, technically, it's an EH and not an EG ;)
ur right bout that. but i was only using hmotors as a reference list as to what he needs if he looked at a list of the complete swap.
lol eh ok.. and yes its a swap i bought it like that so idk much about it. so im guessing i have obd2? and my tranny wont work with the gsr huh?
well what year is the motor? 96+ gsr motors are obd2. so you tell us what you have and we will tell you what you need. like as far as parts wise and stuff.
