dohc zc swap parts search
moosebrew
Hi, I'm in the middle of doing a dohc zc swap into my 90 DX hatchback. I am having some trouble finding a couple of replacement parts.
-The first is what heater hoses do I need to connect to the new motor.
-Second I can't seem to get the correct part number for exhaust gasket that connect from the ZC manifold to the ZC 2-1 down pipe. The one I thought I needed was too large and it looks like its supposed to be two smaller round colapsable rings.
Any help you can lend would be greatly appreciated!
thanks
Mark
Have you try looking at a local Junkyard for replacement parts? or try to look at a Honda Stealer-ship. But they prolly charge u a arm and leg.
I was hoping someone had a part number or could point me in the right direction for the hoses if the stock ones were not the right ones. I know the stock exhaust gaskets wont work and I thought I got the one for a 89 Integra but it is too large of a diameter and the ZC exhaust has two inlets at this section, then it goes into one.
Mark
Mark
stock heater hoses work - upper radiator hose is 88-89 Integra - lower radiator hose is 88-91 CRX/Civic Si - exhaust gaskets for header to downpipe are same as 92-95 Civic D16Z6
