mountainracer1988
LS_TUNER
anyone ever put a b18 head on a b21 block im thinkin about buying this prelude motor and making some good compression with my old head just wanna know if anyone has done it before?
well couldnt find the rules but if you are allowed to use any stock parts get you a set of pistons for a 2000 acura integra typeR or a 1999civic SI. The integra typeR pistons will net you about 11.9:1 compresion. If you mill .020 off the head and you are at 12.5:1 get you a intake cam from a B18B which is a non vtec integra form like 1999. if you do the piston change run 100octane or higher and get a set of 390cc injectors from a automatic turbo eclipse or talon. car will run a little rich but you should be ok and still fall into the stock parts rules with a unmodified ecu
