Will it work
RobertF1
I have a 91 prelude SI Threw a rod through the block i race this car at the track will a f22b1 fit and work and what might i need to swap it out
Yes it will fit. The f series and h series motors are very similar. Just check out info on the h22 swap to see what work needs to be done.
my prelude doesnt have an h22 it had the b21a1
He didn't say that it did. He's saying to research the H22 swap into your car. The F22 swap will be exactly the same. And personally, I don't think it's worth it. It's NOT a bolt-in swap. It requires fabrication. I would just look for another B21...
but if you do the swap look at the aftermarket world. that motor is going to be around for a while. there are less parts for our b21 b20 motors. it is deffinatly worth it if you have the money and knowledge. think about the longrunn... i mean doing an h22
