hunterhound
I want to get a gauge cluster with a tach for my 89 dx 5 spd standard. Which clusters can I get that will make this the easiest possible...by easy I mean pull one out and plug one in with no modificiations?
wrong
there are a few 88-89 clusters which are direct swap replacements which will give you a tach. you could even use a 90-91 si cluster, you just have to switch some wires around.
None
did you read his post!
NO MOD'S
