accordex98
sup guys i have a question i have a 96 accord lx 5spd how come is it dat wen im 4th gear i can onli take my rpms to 6 grand an in 5th gear i can onli take to 4an half how can i stop da rev limiter anybody kno
english again,all im sayin iz dat wen in racin i can onli take my 4th gear to 6 thousand an in 5th gear i can onli tak the car to 4 thousand
rolfFirst, make sure you have a perfectly clean, static free workplace. Then, take the ECU out from under the dash and take it to your workplace. Carefully mark the exact center of it with a felt pen. Now, find a heavy object (3 pound sledgehammer works great, but large rocks will do the job) and hit the ECU as hard as you can. Only do it once though. Now put it back in the car, and your rev limiter will be gone.
Wtf? Is that a actual Hondata chip?here is your rev limiter. open the ecu, pop it out and you are golden.
first, make sure you have a perfectly clean, static free workplace. Then, take the ecu out from under the dash and take it to your workplace. Carefully mark the exact center of it with a felt pen. Now, find a heavy object (3 pound sledgehammer works great, but large rocks will do the job) and hit the ecu as hard as you can. Only do it once though. Now put it back in the car, and your rev limiter will be gone.
