rev limit redline
zap45
ok so i installed a cluster with a tach in my swap dx.
my question is i dont know the true rev limit or redline of my f22b dohc yet? anybody know? btw i have long gears ratio if this make any difference thanks
well when the revs stop climbing and you hear Bwop Wop Wop! then you'll know lol. in all seriousness though, i think its about 6500 rpm
Redline
Here is your answer:
This engine was used in the 1992-1996 Honda Prelude Si in Japan. It is similar to the H23A,.
Specifications
  • 2.2L
  • Bore × Stroke: 85.0 × 95.0 mm
  • Displacement: 2156 cc
  • Valve Configuration: DOHC, 16 valves
  • Compression ratio: 9.3:1
  • Max power: 166 hp (119 kW) @ 6000 rpm
  • Max torque: 150 ft·lbf (200 N m) @ 5000 rpm
There you go, hope this answer your questions.......................................
Good luck....................
