90 Civic Si speed cable
Vtecmonster08
Vtecmonster
I just bought a cable that is suppost to go from the back of the tac to the tranny to see how fast im going , and i pluged it in and the speed still dosnt show?can any one help?
is it a aftermarket cable i had a prelude and i got a cable and the part that went to the cluster was too small so it didnt work so check that out
ive been looking for a speed cable where did u get it from??
eBay is your cheapest option.
So you have the stock tranny for your car right?
Are you sure both sides are put in all the way and correctly, and are you sure you didn't put in in backwards?
a little old but the d16z6 has an electronic speed sensor,and the cluster in the ef's are set for mechanical..
na its a b16a i cant find the cable that was supposed to be behind the cluster it most likley got ripped out
i have a 91 dx with a b16. i pulled the speed sensor outta the trans and just plugged the cable driven speedo in. worked so far.
im glad i found this thread cause my 90 si with a d15b is havin speedo problems. the needles wavin up and down and its makin a rubbing noise as i drive sounds like when your scratching your fingernails on a pair of jeans. vrrrrt vrrt vrrt vrrt vrrt vrrt vrrt vrrrt just like that annoying!! is there any easy fix or do i need a new cable?
is the drive gear down all the way? you have the lil metal tab holdin it in right?
Ok yes its an EF but it was automatic ..LOL...and i got the right cable from another D16z6 but when i connect it to the tranny and then to the cluster it wont catch or "READ" for that mater....now whats this i hear of "ITS electronic" is this true? am i fucked? because if its is how the hell am i going to make that work......?
92 eclipse GS....blown motor
90 civic SI....
Well then ummm.....what the hell does everyone else do?What do i do to make it work..because driving with a tom tom that show's your speed is getting wack..lol..
Yup the car was deff. auto and the weird thing is that the cable fit perfect in the back of the cluster and fits perfect inside of the tranny but it dont work.....what do think i should do?
90 civic si
d16z6 1.6L Vtec
Headers
AEM intake
straight PIPE
Vacf
short shift
stage 2 clutch
MSD
take it out and soak the cable in wd-40 or some kind of lubricant for about 20 mins u should be good after that.
the speed cable teeth might be fucked up in the trans. take it out and look
anyone have options for me?
where the drive gear goes in the trans does it look like this?? hers the cable attatched to the gear. of course yours will most likely be black not yellow
