I just finished up a b16a2 swap into a 89 crx si and i'm having trouble starting it up. It starts up with brake cleaner when sprayed into the throttle body so i know its my injectors, there is fuel going to the fuel rail (i loosent the fuel rail and gas was leaking). Question: can i use the obd2 injectors (I also grounded the fuel injector resistors)? . The other problem i think it could be is my wiring. I match up the solid wire on the injector to the solid and the striped to the striped, is that correct? All the wires were solder together. When i pulled out the fuel rail and injectors and try hand cranking the distributor, only one injector spit out a lil fuel.
