bluerex504
So last night I'm driving and i notice my lights start to dim, my cd player shuts off as soon as I hit the brakes. Then fuel pressure slowly starts to go down (Normally will idle at 51 psi) is more around the 10-20 psi range. And my car finally dies in the middle of the road. Light will barely come on. So i get it jumped and Runs perfect and everything but only made it about a mile down the road before the same thing happened again. This happened 2 more times. I recently got my altenator tested and the brushes replaced in it. And when the car is idiling and I take the battery out the car will not die. So obviously my altenator is putting out. Car is a 91 crx si w/ b18a1 if that helps.
