what did I do wrong? still brake issue
red91efhatch
I know it's getting old me and my brakes.... but now i'm running into an issue where after driving the car from 10-20 minutes the pedal gets rock hard and all four wheels lock up. here's my setup where did I go wrong?Rear disc conversion from DA,Stock EF front calipers,DA non abs 40/40 prop valve,ef civic EX 15/16 bore master cylinder,brake booster ef civic EX, now I am planning on adding the DA front calipers anyone know what may be causing all four to lock up and pedal stiff? any advice is appreciated
It was a while ago, and I don't know what caused it exactly, but sometimes the pedal would just get stiff as hell. I could rev the motor a little bit and it would soften. We deduced it was a vacuum leak, because under higher rpm's it was fine, but once it got to an idle it would get hard again. I sold the car, so I never really looked into it more than that...
check valve on the brake booster is probrably letting air into the booster killing the vacuum which it operates off of when the car is sitting.
