A auth3nt1c New Member Mar 1, 2009 #1 would it be possible to use a gsr obd1 block w/ obd2 head? would i encounter any problems between these two?
Matts96HB . Moderator VIP Mar 1, 2009 #2 Yes it is possible. You'll need everything on the head to be OBD1, and the ECU will need to be OBD1. It needs to match the distributor, basically.
A auth3nt1c New Member Mar 1, 2009 #3 Matts96HB said: Yes it is possible. You'll need everything on the head to be OBD1, and the ECU will need to be OBD1. It needs to match the distributor, basically. Click to expand... when you say everything on the head to be obd1, you mean the sensors?
Matts96HB . Moderator VIP Mar 2, 2009 #4 Well, pretty much just the dizzy lol. Is the car OBD1 or OBD2?
A auth3nt1c New Member Mar 2, 2009 #5 ...... the car is obd2...so it should just plug and play! okie dokie thanks...
Matts96HB . Moderator VIP Mar 3, 2009 #6 Yeah as long as you have an OBD2 GSR ECU and dizzy you should be alright.
