i have a 98 civic dx ek and i want to swap in an h22a.
i'm thinking of buying and h22a 92-95 complete change over through hmotorsonline.com.
here is what i get with the kit...........what else would i need so this swap can go smooth?....other than aftermarket motor mounts and OBD2 - OBD1 harness
- Motor
- LSD Tranny
- ECU (P13)
- Axles with Half Shaft
- Shifter Cables
- Shifter Assembly
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- Motor
- LSD Tranny
- ECU (P13)
- Shifter Cables
- Shifter Assembly
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
