MI 1991 civic bully built and boosted!!!300+whp
91civictsi
1991 honda civic si
b16a1
301whp on a mustang dyno.
motor
endyn RW FI pistons
eagle rods
honda berings and thrust washers
honada oem gaskets
new water pump
new oil pump
b16 head
all new seals
ferrea super alloy valves
crower cam gears
arp headstuds
brand new dizzy moded for msd.
GSR trans
quaife lsd
walbro fuel pump
fuel pressure regulator
3in thermal exhaust
hassport mounts
turbo setup
rev hard turbo kit
garret .60A/R
rev hard manifold
intercooler pipes
front mount
tial 38mm wastegate with dump tube
greddy type s BOV
greddy turbo timer
turbonetics manual boost controller
other
hondata socketed ECU P-28
MSD 6 series ignition/ 2 step and launch control
autometer fuel pressure gauge
autometer boost gauge
momo stering wheel/hub
sparce seat
harness
kenwood radio
new aftermarket speakers
new battery/ converted to rear
new upper and lower ball joints
new outer tie rod ends
all energy suspension bushings
energy suspension shifter bushings
traction bars
brand new tires
lots of other things im sure im forgetting ill add more to the list as i think of them.
the car just got a brand new thermostat and coolant temp sensor.
new exhaust gaskets.
new headlight bulbs.
and a oil change.
extras
2 tires
energy suspension shifter bushings NIB
2 sets of cap and rotor NIB
extra dizzy has bad coil
the car has alot of money into it and i have every receipt for it.
if you have any questions feel free to ask them.
im looking for trades or 6500obo.
trades can include car for car, my car plus cash or your car plus cash.
I dont think your going to get 6K for that, but yea underhood shots and a dyno sheet would help with the sale
gl
It's definitely clean on the exterior, gotta give him that much. Underhood shots and dyno sheets would be nice though.
i will post underhood shots and dyno sheet tomorrow.
and just so everyone knows i have a receipt book of a literal 15k in parts for this car
lol at the dyno sheet, so youve had this car boosted for 6years? and i guess you swapped in a b16a1 after dyno? it sys b16a (two totally different hp specs)
noob post huh ? how is this a noob post? this guy seems a little shady , so i just pointed out a few things.
i don't think he was referring to your post.
its at least well laid out
but it is suspicious he only has 2 posts and its a 6 year old dyno, but leaving the 1 off of a b16a1 can be a mistake but 6 years is a huge gap. Which is why you test drive and make sure of receipts. Cause if and when it blows, if those are legit, you go after him. He did state it was the only dyno pic he had at the moment though.
sorry it was not supposed to have a 1 after b16a.
yes this car has been boosted for 6 years.
there is 35k on the build.
205k on the body.
i will have tons of more pictures as soon as the weather gets warmer.
the car has not seen snow in 8 years. it is stored from November till April every year.
im sorry if i seem shady to some because im a newb on here, i understand because im am the same way with the newbs on the other forums i am on.
but i will get you any and all info or pictures you need.
quite n00b... you realize people refer to obd0 b16's as b16a1's sometimes because it was the first gen b16
and yes, you're a n00b
205k on the body.
i wasn't calling you a noob. i was giving you props for posting a legit add. it was broken down just fine and had pictures/location/price. most people are just like, "i have a ef hatch, text me an offer" and thats it.
205k on the body.
Post up your username to the other forum your from and people will take it a bit more seriously.
Holding up for 6 years boosted is pretty good, along with the mileage is great.
my user name on xceedspeed is 91civic_tsi
user name on civic 4g is 91civic_tsi
if i do not sell this in a month or so it will be turned into another project.
either a boosted k20 or make my ef AWD
i would consider putting a stock motor in there and parting out your turbo setup. you could probably get $3-$3500 for it with a stock engine and $3-$4k for the engine parted out.
i would do that its just money is tight right now since i lost my job.
witch is the main reason why it is for sale.
i just cant afford 3 cars right now.
if i get a job tho then this will not be for sale anymore.
