what else Needed to install these Cams?
Domi31
I just picked up Skunk2 titanuim retainers, Skunk2 Vavle Springs, and Sk2 Stage 2 pro Cams. These will be going into my b18c ITR motor. This was an unexpected purchase for myself, and they wont be going in untill summer, I just thought I had a deal and did not want to miss it. I just have a few questions:
1. Picked everything up for $800 bucks, brand new in boxes from a guy who never got to install them because of an accident with his car (ex cam box still not even opened) So was this a good deal?
2. Seconded Q, what else would you guys advise I should pick up before they go in? (brand of cam sprokets, or any thing else I need to install these things) am I missing anything?
I have a P28, and a S200 hondata and starting to save for a some dyno tuning
Skunk2 recommends degree'ing the cams. Email them for the cams specs to do so. They also say if you have no idea how to do this, to just advance the exhaust 2 degress and retard the intake cam 2 degrees. I might have the backwards.
I use the Red assembly lube because it was advised by a friend of mine to be better than the white assembly lube people use.
As far as break in procedure... email skunk2.
will due, thanks
new cam seal, skunk2 perhaps, i know i'ld be pissed if a week after i installed all those goodies it started leaking
