engine mount question
intafocus
will a 99 sohc vtec motor bolt up to my ef without modification
No. You need to use the search feature my friend! You're getting into electrical, ECUs, mounts, cable vs hydro, etc.
He is just asking if it will bolt up. Yes, if it is a d-series then it will bolt up to your stock manual tranny and your motor mounts. Now if you want it to run then that is were your problem starts.
If you want to put this in your car the best thing to do is wire it up for multi point if it isn't already then convert to obd2a or obd2b not sure which one. for that to happen you would need the dizzy, ecu, injectors, jumper harness.....I think thats it. More trouble than it is worth if you ask me.
to make it bolt right in you have to take the complete driver side mount off your old motor and put it on the new one
