Hey guys, I recently did a OBD2 GSR Swap on my 90 Integra. I am using my OBD0 LS Harness, a Sub Harness that I ordered from eBay for Vtec/knock/O2/IAB, OBD0 PR3 JdM ECU, stock LS OBD0 Dizzy with one bracket cut off to fit in position, my stock OBD0 fuel rail and injectors. When I finish the swap, added oil, coolants, and adjust my clutch. Somehow the GSR motor seem to almost crank over but never did. I can hear fuel coming. Acourse, I had premium gas in the tank.
The motor seem healthy, as it wanted to crank over but it ju st won't. Can someone out there help me out because I am stuck and getting really frustrated.
Thing that check:
1. Unplug fuel line from fuel filter to see if there gas. There are gas coming.
2. Check dizzy. First there were spark and now there isn't. But dizzy work. Tested on another integra and just recently use 3 other dizzy that I am for sure still work. Still no spark.
3. Tried with stock PR4 ECU and JDM PR3 OBD0 ECU. No luck.
* can it be my sub harness because that is the only thing that I did not plug up to the ecu yet. I know if those are not the problem because they are sensor and people tell me that that's not the problem.
Thing that check:
