adding vtec??
hale97
i have a 97 integra non vtec 1.8L. i am looking for any info/advise/tip i can get about instaled a vtec head and how much work is involved. or if it is more worth while to find a vtec engine and just sway them out??
well that^^^^^ doesnt help.......... has anyone added vtec to a non vtec engine? i need to know how difficult it would be? or if its worth the hassel? or if its possible? any info would be great.
Many have added VTEC to a non-VTEC engine it's not that difficult, but it does require a bit of effort on your part. Do a search on an "LS VTEC" there are dozens of write ups on it and if you just read a couple of them you should be able to do it on your own.
hate to be captain douche bag but seriously the apocalypse wont come when you use the search function so its okay to use once and a while
what head would you suggest using? or is one really better than the next??
there are tons of guys who have done LS swaps, you arent going to get as much power out of just a GSR head swap as opposed to getting the entire GSR engine
i figured that, but from what i understand it the ls block is supposed to be better to turbo. and being on a bit of a tight budget i was thinking that would be a solid way to go(with the gsr head). or do u think a b16 head would be better? thanks
you sir are a tard...more displacement equals more power:facepalm:
Your posts make my head hurt. First off he was right you can't get as much power out of a LS/Vtec that you can get from a full GSR.
Next again your posts make my head hurt. The flow charts between the heads are almost the same, you're thinking of the B16 intake manifold that flows better than the GSR IM.
hale97 please don't listen to this NOOB he and his 152whp have no idea what they're talking about.
your posts make my head hurt. First off he was right you can't get as much power out of a ls/vtec that you can get from a full gsr.
Next again your posts make my head hurt. The flow charts between the heads are almost the same, you're thinking of the b16 intake manifold that flows better than the gsr im.
Hale97 please don't listen to this noob he and his 152whp have no idea what they're talking about.
haha
