So in the fall I bought a kit from Summit. Installed it. It failed twice. I installed a regular filter and set the kit aside until it warmed up.
Fast forward to now. I figured out that the flimsy O-ring that Summit included with the kit was the problem. It was thin and rounded, unlike any normal oil filter O-ring which are beefy, thick, and flat.
So to solve this problem I actually removed the O-ring from an oil filter, modified it, and siliconed it into place.
I believe with a little more silicone between the O-ring and the block I have solved the original problem with the kit. What do you think? Will it work?
Also, do you think the new O-ring sticks out too far from piece? Should I make it smaller or is it good the way it is?
