Random parts FS, check it out!!
itrsleeper
Gotta bunch of random stuff up for sale check it out, every thing is obo!! but buyers pay shipping (everything will be shipped flat rate for $10 as long as i can fit it in flat rate box)
B series LS parts (every thing was pulled of running motors, none had any leaks. One had bad rings and other had blown head gasket)
-Water pipe (from water pump to thermo housing) got 2 $10 each
- Water pumps (both work no leaks) x2 $10 each
- Thermo housings x2 $10, $20 (for one with water neck and thermo)
- Oil Pump $10 (works no leaks, seal still good)
- Upper Alternator brackets x2 $10 each
- Lower Alternator brackets x2 $10 each
- Evap can $10
- Timing belt cover (lower) x2 $10each
- Rear main seal $10 (no leaks seal still good)
- Crank timing belt pulley x 2 $5 each
- Drivers side motor mount $10
- Oil pan $10 (has dent on front corner, and has scrapes, doesn't leak)
- Oil baffle $10
- Oil pick up $10
Misc. Distributor parts
-Housings $10 each (GSR, LS, B16, i think...cant remember obd1 and obd2)
- ICM (igniters) x 6 $10 each (these things sell for almost 200 new!! but dont know if they work, cheap way to try and fix dizzy problems)
- Internal Coils $20 each x 4
- Internal pick ups $10 each (things with gears on them, actually are crank pos. cam pos. piston pos. sensor pick ups)
- caps $5 each
- rotors $5 each
Misc injectors $5 each
B-series vtec solenoid $50 ( broken wire, just needs terminal end crimped back on, easy fix!)
D15 vtec cams $40 each obo
PM6 88-91 civic/crx si ecu sold
PM9 88-91 civic std ecu $40
USDM ITR valve cover sold
CTR gauge cluster bezel $20 shipped
B-series power steering pump with aem pulley and mounts $60 obo
ITR fuel rail $50 obo
B-series alternators all working 2-obd2 and 1-obd1 $40 each obo
B-series intermediate shaft $60 obo
B-series starter sold
more stuff to come.....................thanks for looking!!:D:D:D:D
pm'ed back
Do you think the D15 camshaft will work in my D16y8?. I have the D15b7 distributor anyway.
i think they can....there are alot of write ups about which cam is better....d15 or d16 but not really sure....
https://hondaswap.com/general-tech-maintenance/d15b-cam-help-69772/
http://www.honda-tech.com/showthread.php?t=1248924
http://www.d-series.org/forums/naturally-aspirated/24275-59300-d16z6-camshaft-into-d15b-vtec.html
hope it helps!
hey do you know if that guage bezel will fit in a 96 civic dx? (cluster has tach but car is auto)
edit... actually looking back at it now, it probly wont but im not sure.. gotta do somr research r/q
it will fit in the cluster however the spacing for all the lamps (seat belt, turn sig...etc) is different. thats pretty much all i know about it. never even put it....just ran with the ol' Si cluster.
shat... i might just take out my cluster and make a custom carbon bezel from the original... like, make a template and do a one off... yeah.. cant wait to get that damn car! gotta wait for paint and shit to get done and it's mine
Hey, I do not know if I already asked but do you have a D15b7 distributor housing?.
very int. in pm6 might u have resistor box and dizzy for mpfi swap?
