chassis harness ???
hatukazi
ambitious...but rubbish
ok I traded my stereo for a 90 hatch shell, and the ecu plugs look like this
I tried a chassis harness I pulled out of an 88 crx I scrapped, but a bunch of the plugs are different, there is an 90 EX in the u-pull-it right by me but it is an auto, how much different is the auto chassis harness, ideally i would like one already pinned and plugged for MPFI since this is a PITA of a job and I have an extra 90 crx Si engine harness.
does anyone know if a DA chassis harness plugs to an Si harness? they are a little eaasier to find, and already MPFI.
the rest of the shell is nice though, I need to put my LS/GSR swap in this so my kids can ride with me.
wow..!!!!
if that was my car i would look for a eg and make the whole car
obd1 ...lsv take the harness off a si buble...
obdo is playd out and not worth putting together...
i understand it may be more difficult to find but the best thing to do is get an si chassis harness, since you already have the si engine harness. that way it will already be mpfi and you'll be good to go. trying to convert the whole car to obd1 with an obd1 vehicles harness would be not a good idea. that would require you to use the matching vehicles dashboard. probably not the kind of work you're looking to put into it.
says it has some damage, may want to ask exactly what is wrong.. but it may work for you.
honda crx civic si body wire harness 88-91:eBay Motors (item 250432902383 end time Jun-01-09 11:54:53 PDT)
you bugging....
my and a friend of mine did a 2 door ef..
from head to tails obd1 using a 95 bubble harness..
and there was no need to swap out the dash...
you bugging....
bugging? an odb1 harness has different plugs in comparison to the obd0 harness. the plugs for the ignition are different, heater and a/c are different, as well as gauge cluster plugs. its far from plug and play.
thats what im saying convert the whole car obd1..
you deff gonna have to use the obd1 cluster and a lil work it will fit flush
in the ef dash..
screw a/c
heater i dont remember how we did it...
but if the car has cut plugs
i would up grade
YES its gonna take a lil more time
but i would feel better then a step up harness.
