Someone Help! D16z6
delsolcharlie
ok i have a 93 civic del sol...with supposdely a D16Z6..is what the vin number tells me..my valve cover does not say VTEC..asi found out the D16Z6 was a VTEC..i have no solenoid..WHAT IS IT!!!
if the motor says d16z6 but it dont have a solenoid its missing or its a non vtec head
it will be on the front right were the motor and tranny come together, about a inch flat spot that will say d16z6 or d15b7 i think
i dont have a valve cover that says vtec or a soleniod....here is what it looks like
not my car but i dont have a pic of my engine and this is what it looks like
where is the soileniod ??
it willl be right beside the pvc valve on the valve cove it will have a green plug on it
any 88 or newer d series but stick to 92+ because those are hydo like yours
here's where the solenoid should be if there is one. I made an arrow pointing at the one in the picture.
just becouse it dosnt say vtech dosnt mean its not i have a buddy with the 93 si too. and his valve cover dosnt say vtech and it is.
Hahahahaha!!!
I'm sorry but it makes me laugh every time I see it spelled that way.
Ya my Si doesn't say Vtach on it either. Like mentioned above just look for the vtach solenoid with the green plug on it.
Hehehehe
I have the same motor. Mine has the vtec. My plug itsnt green tho. I did a swap and snagged a plug that had the same connections. I have a stage 1 cam from comp cams in and when it engauges at 4800rpm you can hear it. It sounds so alsome! ^_^ lol
hearing it is a bad thing and this thread is super old
