can someone tell me what wires connect to what wires? i baught a dizzy for my b16 swap and the plugs are cut, what color wires go with what color on my si harness??
yeah trust me i understand, for the past month i been doing 32 hours straight at my job... they allow 4 hours of sleep after 16 hours but still... it drives me nuts
TD22U is JDM OBD0 B16A distributor - wire colors should be the same as on the Si harness - just match them color for color - there are 2 white wires - if you get them switched, it won't start - the white igniter wire is a little thicker than the other one - on the Si harness connector, the igniter wire is on the end of the middle row, opposite the empty pin
