Throttle Cable for B18c Into 1991 Civic EX
RubyCivic3
OK, I have tried several different GSR cables for this and I am not getting a good fit. HASPORT says in the intructions to go with the 90-91. Is this correct?
Can you all give part number and year?
I used my stock DPFI throttle cable on my B16, cut down the cable and the housing than put a barrel nut on the gas pedal side, it was cheap and works.
