Sunroof
Hondaman3421
The motor in my sunroof went bad does anyone know how hard it is to change or how to change it
it's toast, you should sell me your CRX. :D
jk, it's not too hard to pull, what exactly went bad - the whole shebang or just one of the actuators that makes it open or close?
there are two actuators; one that opens the roof and one that closes it. so there you go. the motor's fine, the actuator's crap, and if i recall due to the amount of plastic involved, those are pretty much not fixable (at least in any permanent way). best bet might be to buy a replacement assembly off of someone parting out their car.
:shrug2:
ummm not sure when i hit the switch it sounds like its trying to open but nothing happens
if you help it along will it move? and is it slow moving im both directions? if so then its most likely the motor that went bad. and there is only one of those. unfortunately its kind of a pain in the dick and you have to drop the headliner in order to replace it.
or if you cant find used parts or want new OEM.
hondaautomotiveparts.com
They sell OEM honda parts at 30% cheaper, they have saved me tons on replacement parts.
Or you can just sell Dacheat your crx. lol
Good luck at a recycler but its the cheapiest. I would go with the new OEM stuff
I get my stuff from hondapartscheap.com but the other one given will work well too
