crx gass tank
TITO.CIVIC
Ok b20 members I have a 1988 crx si and I have to bring the fuel tank down so I can change the pump. But ill like to know if is posible that I can use a ef fuel tank? And if I don't have to change all the lines to do that.thanks
Your 88 Si is an EF.. So through your jumbled confusing version of english, I'll assume you are asking if you can use the stock fuel tank for your B20 swap. If that is the question then yes, you can. No swapping or modification or anything necessary.
No that's no what I'm asking. In orther for me to take the fuel pump out of my crx I have to take off the tank.but the civic ef have the pump right under the back seat.so ill like to know if I can swap the tank to the civic ef and what do I have to do.
Your thinking EGs (92-95 Civics) they have the fuel pump under the seat. The EFs (88-91 Civics and CRXs) wether it be a Civic or CRX you have to drop the tank to get to it.
you're thinking of either an EG or an EK tank. your crx IS an EF. and your answer is no, the EG or EK tank will not bolt up to your crx. you could "make" it fit, but it's really not worth the hassle. pull the tank and put a walbro pump in there. you'll never need to replace it again as long as you own the car.
you're thinking of either an EG or an EK tank. your crx IS an EF. and your answer is no, the EG or EK tank will not bolt up to your crx. you could "make" it fit, but it's really not worth the hassle. pull the tank and put a walbro pump in there. you'll never need to replace it again as long as you own the car.[/quote
yeep good ol walbro...they always work great. until some ol lady runs a stop sign and t bones my pass door....damn old ppl
