Nitrousoxide (NOS is a brand, dude) introduces highly combustible nitrogen into the chambers along with extra oxygen to burn, it's the perfect fuel and a great power adder if you don't use too big of a shot for your build or use it at low rpms. That's my opinion.
Oxygen :fr:
In vehicle racing, nitrous oxide (often referred to as just "nitrous" in this context to differ from the acronym NOS which is the brand Nitrous Oxide Systems) allows the engine to burn more fuel and air, resulting in a more powerful combustion. The gas itself is not flammable, but it delivers more oxygen than atmospheric air by breaking down at elevated temperatures.
Nitrous oxide is stored as a compressed liquid; the evaporation and expansion of liquid nitrous oxide in the intake manifold causes a large drop in intake charge temperature, resulting in a denser charge, further allowing more air/fuel mixture to enter the cylinder. Nitrous oxide is sometimes injected into (or prior to) the intake manifold, whereas other systems directly inject right before the cylinder (direct port injection) to increase power.
Since nitrous allows a much denser charge into the cylinder it dramatically increases cylinder pressures. The increased pressure results in heat, and heat will cause many problems from melting the piston, cylinder head or valves, to predetonation.
