I have a '93 del Sol S with a D15b7 in it. I was planning on swapping out the head for a D16z6. Does anyone know where I can find exactly everything I'll need to make this swap work? Also, if I do this can I keep my stock tranny or am I going to get a Si tranny? Thanks.
Try searching. There's plenty of info on the "Mini Me" already on this site.
As for the transmission, you're not changing the block, so why would you need to change the transmission? You might want to though, for the better gear ratios...
That's interesting. So the EX has a longer 5th maybe? I just can't imagine that 1st-4th would be longer on an EX transmission since it's supposed to be the performance model...
