I'm currently pulling a motor out of my donor car which is a 92 Integra, with the obvious obd1 b18a1 matted to the Ys1 cable tranny. I know that I'm going to use the axles, wire harness, ecu and clutch peddle assembly from this car.. but my only concerns are what swap mounts do I need, considering that I'm going from a D-series auto to a 5-speed b-series "cable trans", also I'm pretty sure that my D-series auto trans has a electronic speed sensor on the trans... and the b18 has a cable speed sensor, how I do fix this problem that I'm going to face with my cluster..
Also I'm about to order my delsol b16 shift linkages sometime in a few weeks, unless I find someone selling them before hand.
Thanks, Joe.
Thanks, Joe.
