oil pump removal d16y8 to d16z6
poloboy4
dose anybody know the process? i been working on this motor keeping it obd2 now i think i just need the swap the oil pump to make the motor turn on this way i can add the crank sensor.
putting z6 oil pump on a y8 block?
then where will you put the dipstick?
Can't I keep it in the old spot and block off the new one?? I mean putting y8 oil pump on a z6
Drain oil, take off the oil pan, unbolt oil pickup, remove crank pulley, remove timing belt cover, loosen tensioner and take off the timing belt, unbolt the oil pump.
Seems like alot of work half way there but I'm not sure if It will work :( well I'm gonna do it on my next days off will I need a new oil pan gasket?
It's pretty simple as the only thing hard to get off is the crank pulley. Rest is 10mm bolts.
It's recommended to change any gaskets since you're already in there.
ok thanks for the info d-mon that site looks good thanks! and well yeah gona see if i can do it this Sunday or Monday.
there is a ckf bypass that you can bo by runing a few wires to the dizzy do a search you should find it on google
