hows this for a setup? ( d16a6 )
lilsicsol
i lOve my Ef sedaN..
whats up fellas how you all doing...
i have a 89 zc motor that spun a bearing
and in a few days im going 2 pick up a d16a6
my idea for my set is
d16a6 block
zc dome pistons
and
a d16y8 head...
those this sound good?
i know when you put a y8 head on a d16a6 block
the comp goes up ..
but how much more will it be with the zc pistons?
i do not think you will be able to run that setup..i think the pistons are going to be too tall and crash valves...but im not positive
i was thinking the same...
just wanted to know if enii 1 had done this.....
think ii might just do the pistons and keep the stock head...
enii more input???
any...a-n-y. although it may be pronounces "en-ii" this is not the correct spelling.
todays lesson brought to you by, the letter J. as is "Jackass why cant you spell any?"
oow shit feel better about your self?
brought to you by... me...
jump off ma dick....
that would make 13.5 comp lol with a z6 head it would be 12.7 thats streetable with 93 i done 13 for a long time i have a b7 block zc pistons z6 head with y8 gasket. it was a beast for a na d
Compression Calculator - Honda, Acura Tech Website, tutorials, tuning and HOW-TO's. Drag racing, street racing, road racing - C-speedracing.com
use that from now on
depending on which head gasket you use, i get 11.6 to 12.46 for the Z6 head and 12.3 to 13.08 for the Y8 head
piston to deck height with the DOHC ZC PM7/P29 pistons is 0.040"
You could try this, its a no-tec setup but who needs vtec?
D16a6 block (75mm bore)
D16a6 crank
D16a6/ LS rods modified to fit crank (137mm)
D16a1 P29 pistons
D16a6/b2/b7 head (0.005 milled for resurfacing)
D15b7/a6 head gasket (0.048in)
Block deck milled (0.020 in)
11.50:1 compression ratio W/ 1590cc dis
0.019 piston-to-deck height
1.52:1 rod / stroke ratio
