umm.. have you tried checking the codes from teh ecu? i'm sure it'll explain why the speedo isnt working..
changing a VSS is easy.. 2 bolts.. pull it out, replace
on the passenger top side of the tranny, kinda behind the motor, below the thermostat
yes.. its under the hood.. where else would the tranny be.. lol..
here is a pic of it... if i had the teggie here i'd take a pic of it for you.. the woman has it
It's on top of the transmission.
Get a shop manual and go to the index. Look under V. Go to VSS. Follow directions.
the Vehicle speed sensor (vss) if you are getting confused looking at a manual than take it to a shop cuase i know for a fact they are called vss in every manual ive read thru
