fuel pump stopped working today,main relay does not click on and off ,i turn the key to on position and nothing happens,could it be my main relay or bad pump,any ideas?? need your guys help...
Does your check engine light cycle once when you turn the key to the run position? If not could be a loose ground at the thermostat housing. if yes, then relay.
