crx door help ?
AHHVTEC
Well-Known Member
VIP
was wondering will 91 crx doors fit on a 88, i mean are they the same door other than the panels
ahh thats right i knew i was forgetting something, thanks man
well the 88 does not, im also thinking the molding on the 90-91 is higher up
Honda part numbers for the door skins are the same on all of them - i think that just the molding itself is different
The window of the door mounted seatbelt is about 1" narrower than the window of the piller mounted doors. This is because the back of the door frame is wider to fit in more support for the seatbelt mechanism.
the canada built hondas had the seatbelts on the pillar, the one built for american specs have them on the door. i believe this is true for all 88-91 models, my 89 has them on the pillar and was built to canada specs. it has the sticker on the radiator support
all i know for sure is that a 88 hf has them on the pillar, because im looking at it lol
so did you ever find out what doors will fit? i thaught in 90 they made the crx a little longer, but i dont know what they stretched. the doors or just the body
well from what i can tell the doors are almost the same other than seatbelt, door impact bars and the molding is a little different, but for years i have thought the doors on the 90-91 was a little shorter from bottom to top, but i cant find info on that, but im confused because i didnt think that for years for no reason. i dont think anyhow lol.
The 88 Si had pillar mounted belts. If I were you, I'd just wait it out and get the correct door.
yeah thats what im gonna do, im thinking of just reparing the ones i got i was just hating to put that much bondo on it.
