I'm looking for a few things for a friends Del Sol. I don't know the EG chassis too well so I want to make sure the parts fit.
I'm looking for the lug nut covers for the Del Sol rim. They look like they are the same size as the ones on the civics of the same year, but I'm not 100percent sure on that. Can anyone confirm?
I'm also wondering if the power window/locks control panel on the driver side door would match up with the Del Sol set. I imagine if it did, it would have one extra window switch. The Del Sol's controls are pretty bashed up, so it would still be an upgrade.
And a technical question: The outside door handle doesn't open the door but the inside door handle does. I've only been inside a car door once or twice. Isn't there a bar that goes to the outside handle? I suspect that may have been knocked loose. It also appears someone tried to pick the lock in the past, so it may have just been completely broken.
Thanks for the answers, as always!
