h22 rewire into civics harness
russlan44
hey new to HS and i was looking around and still cant find how to or any write ups on hacking preludes and civics wiring.
i have 93 prelude h22a1 motor with full wiring
94 hatch with auto motor harness
need help combing harnesses and i know a lot of ppl just send theirs out and get it done, has anyone done it or anyone knows of any diy? pics or links would help. tx
all you have to do is use a y-8 harness and extend plugs and get pig tail set up for h22a1 dizzy and splice into h22 injector wires and resister box and run hot wire off of resister box to ignition and extend alternator wires to alternator then do the ckp trick and your good to go.. if this helps rep me up..
get the vtec wiring harness for your year off of the d16z6, (sorry "97h22" but the y-8 is for your car 96-00 he needs 92-95) and then you will need the h22 wire harness or f22 ... basically get the harness and start to put it on while the motor is out of the vehicle it will make it easier.... and you will start to see the wires you need to extend like your alt wires up over the valve cover and maybe the intake air temp ...etc.... i cant remember all of them right off the top of my head...
Tech - Injector Wiring
this will help too..
:D
this sensor in front of intake manifold,
and these two sensors
anyone knows where thouse sensors go to ecu
the blu/blk goes to iacv and yell/ blk goes to air temp on side of intake mani,it has a white sensor sticking out ..
blu/blk to iacv to which wire, and yell/blk to air temp which wire is it same colors wires like blu/blk and yell/blk? tx
vacuum sensors
the two vacuum sensors that u are talking about ,u dont plug in just route the vacuum lines to them as illistrated on the diagram,the only plugs you need is the map ,then u are good to go,if this helps rep me up....:D just use your old map sensor or if you want i have an extra one..
I'm in CA and want to pass ref station and thouse plugs are part of smog system, plus in still confused were to tap in that one sensor on intake manifold
