critiques please...
Dustin_m
I've started taking both a Java and a C++ class this semester. I'm done with all required classes, so while waiting to get into a school to transfer, I'm taking a couple classes for fun. I thought I'd post up some of the small assignments I've done so far to see if it all looks ok. Yes, this is beginner stuff, but I remember always seeing you guys on here bitching about people developing bad habits from the get go, so I thought I'd put my stuff out here and let you pick it apart. Let me know where I'm doing something wrong or in a way that's inefficient.
This first one is the only C++ assignment so far, and it's short.
Code:
asst1.cpp       -       This program calculates the area and
                        circumference of a circle
Dustin Michelson
Sep 7, 2009
#include <iostream>
#include <cstdio>
#include <cmath>
using namespace std;
int main()
    double      radius ;                                //Declares radius variable
    cout << "Please enter the radius of a circle\n" ;   //Prompts user for data
    cin  >> radius ;                                    //Gives value to radius
    cout << "\nThe area of the circle is:\t\t" << (M_PI * (radius * radius)) << endl ;  //Prints radius to screen
    cout << "\nThe circumference of the circle is:\t" << (2 * M_PI * radius) << endl ;  //Prints circumference to screen
    return 0 ;
and here's the Java ones.
Code:
/*coinsToDollars.java
 *This program will give the total dollar value of the amount of coins entered by the user
 *Michelson, Dustin
import java.util.Scanner;
import java.text.DecimalFormat;
public class coinsToDollars
  public static void main( String [] args )
   Scanner scan = new Scanner( System.in );                        //instantiates a Scanner object named scan
   DecimalFormat pricePattern = new DecimalFormat( "$#0.00");    //instantiates a DecimalFormat object named pricePattern
   double quarterValue, dimeValue, nickelValue;        //initializes a variable to hold the total value of each type of coin
   double sum;                        //This will hold the total dollar amount of the coins
   System.out.print( "Enter the number of quarters: " );    //Prompts user for number of quarters
   int quarters = scan.nextInt( ) ;                            //Puts user input into quarters variable
   System.out.print( "Enter the number of dimes: " );        //Prompts user for number of dimes
   int dimes = scan.nextInt( ) ;                            //Puts user input into dimes variable
   System.out.print( "Enter the number of nickels: " );        //Prompts user for number of nickels
   int nickels = scan.nextInt( );                            //Puts user input into nickels variable
   quarterValue = quarters * 0.25;        //Changes the number of quarters into a dollar value
   dimeValue = dimes * 0.10;            //Changes the number of dimes into a dollar value
   nickelValue = nickels * 0.05;        //Changes the number of nickels into a dollar value
   sum = quarterValue + dimeValue + nickelValue;    //Calculates the sum of the coins
   System.out.println( "The total value of the coins is "
                                       + pricePattern.format( sum ));        //Prints the total dollar value to the screen
Code:
 * @(#)domainName.java
 *This program will let the user input a name,
 *then it will turn that name into a domain name by adding
 *a www. to the beginning and a .com to the end
 * @author Dustin Michelson
 * @version 1.00 2009/9/14
public class domainName
   System.out.print( "Enter a word that you would like to turn into a domain name: " );
   String domainWord = scan.next( );
   System.out.println( "Your domain name is:  www." + domainWord + ".com" );
Code:
 * @(#)smallerOfTwoRandomNumbers.java
 *This program will randomly generate two numbers between 0 and 100,
 *and will print the smaller of the two
import java.util.Random;
public class smallerOfTwoRandomNumbers
   Scanner scan = new Scanner( System.in );    //instantiates a new Scanner object
   Random random = new Random( );            //instantiates a new Random object
   int number1 = random.nextInt( 100 - 0 + 1) + 0;        //genereates a random number between 0 and 100
   System.out.println( "The first random number is " + number1 );    //Prints the first random number
   int number2 = random.nextInt( 100 - 0 + 1) + 0;        //generates another random number
   System.out.println( "The second random number is " + number2);    //prints the second random number
   if (number1 < number2)    {            //Determines which word is longer and prints the longer of the two words
            System.out.println ( "The smaller of the two numbers is " + number1 ) ;
               } else     {
                   System.out.println ( "The smaller of the two numbers is " + number2 ) ;
Code:
 * @(#)longerOfTwoWords.java
 *This program will let the user input two words.  It will then determine
 *which of the two words is smaller, and output that word
public class longerOfTwoWords
        Scanner scan = new Scanner( System.in) ;
        System.out.print( "Enter your first word: " ) ;      //Prompts user for first word
        String firstWord = scan.next( ) ;                    //Puts user input into firstWord
        System.out.print( "Enter your second word: " ) ;    //Prompts user for second word
        String secondWord = scan.next( ) ;                    //Puts user input into secondWord
        int firstWordLength = firstWord.length( ) ;            //Sends the length of firstWord to firstWordLength as an integer value
        int secondWordLength = secondWord.length( ) ;        //Sends the length of secondWord to secondWordLength as an integer value
        if (firstWordLength > secondWordLength)    {            //Determines which word is longer and prints the longer of the two words
            System.out.println ( "The longer of the two words is " + firstWord ) ;
               } else     {
                   System.out.println ( "The longer of the two words is " + secondWord ) ;
Code:
 * @(#)futureValueOfInvestment.java
 *This program will let the user input an initial investment amount and
 *an interest rate, and will calculate the value of the investment in 5, 10, and 20 years
public class futureValueOfInvestment
   System.out.print( "Please enter a value for the initial investment in whole dollars: " );
   double initialInvestment = scan.nextDouble( );
   System.out.print( "Please enter a value for the interest rate in decimal format: " );
   double interestRate = scan.nextDouble( );
   double value5yrs = Math.pow((1 + interestRate), 5) * initialInvestment;
   double value10yrs = Math.pow((1 + interestRate), 10) * initialInvestment;
   double value20yrs = Math.pow((1 + interestRate), 20) * initialInvestment;
   System.out.println( "The value of the investment in 5 years will be "
                                           + pricePattern.format( value5yrs ));
   System.out.println( "The value of the investment in 10 years will be "
                                           + pricePattern.format( value10yrs ));
   System.out.println( "The value of the investment in 20 years will be "
                                           + pricePattern.format( value20yrs ));
Code:
/*     This program will calculate and print the area and
 *    circumference of a circle with radius 3.2 inches
 *    Michelson, Dustin
public class areaAndCircumferenceOfCircle
   final double PI = 3.14159;
   double radius = 3.2;
   double circumference = (2 * PI * radius);     //Equation for the circumference of a circle in terms of the radius
   double area = (PI * (radius * radius));        //Equation for the area of a circle in terms of the radius
   System.out.println("For a circle with a radius of 3.2 inches:");
   System.out.println("\tThe area of the circle in inches is " + area);                        //Prints the area
   System.out.println("\tThe circumference of the circle in inches is " + circumference);    //Prints the circumference
Code:
/* This program will convert 2, 5, and 10 inches to millimeters
 *    Michelson, Dustin
public class inchesToMillimetersConverter
   final double CONVERSION_FACTOR = 25.4;    //There are 25.4mm in 1 inch
   double lengthInMillimeters;
   int lengthInInches = 2;                    //Sets the length in inches to 2 to calculate the length in millimeters
   System.out.println("The number of millimeters in 2 inches is " + (lengthInInches * CONVERSION_FACTOR));
   lengthInInches = 5;                        //Sets the length in inches to 5 to calculate the length in millimeters
   System.out.println("The number of millimeters in 5 inches is " + (lengthInInches * CONVERSION_FACTOR));
   lengthInInches = 10;                        //Sets the length in inches to 10 to calculate the length in millimeters
   System.out.println("The number of millimeters in 10 inches is " + (lengthInInches * CONVERSION_FACTOR));
Code:
/*     This program will convert 10, 50, and 100 pounds into their equivalent amounts in kilograms
 *    Michelson, Dustin
public class poundsToKilogramsConverter
   final double CONVERSION_FACTOR = 4.54E-1;    //There are 0.454 kilograms in each pound
   double weightInKilograms;
   int weightInPounds = 10;                    //Sets the weight in kg to 10 to convert to pounds
   System.out.println("The number of kilograms in 10 pounds is " + (weightInPounds * CONVERSION_FACTOR));
   weightInPounds = 50;                        //Sets the weight in kg to 50 to convert to pounds
   System.out.println("The number of kilograms in 50 pounds is " + (weightInPounds * CONVERSION_FACTOR));
   weightInPounds = 100;                        //Sets the weight in kg to 100 to convert to pounds
   System.out.println("The number of kilograms in 100 pounds is " + (weightInPounds * CONVERSION_FACTOR));
well the biggest bad habit for programmers to kick is inline variable usage.
I saw it 5-6 times in your examples. its stuff like:
Code:
Now i know you just started the class so im not trying to harass, because i know it will be covered later. But other people end up looking at code when you do this for a living and I generally cringe when i see output done that way.
1) Don't use functions inside outside of defining a variable
Code:
System.out.println( "Your text" + func( var ) );
Define a variable instead.
Code:
final=func( var );
System.out.println( "Your text" + final );
2) MANY places you will work have coding guidelines that forbid you from concating inside of a function:
Code:
final=func( var );
Will be this:
Code:
msg="your text";
result=func( var );
final=msg + result;
System.out.println( final );
Now the above is super simplified and the chances of working in an office that has a coding guidelines setup this way is pretty slim, but if you're working for a SAS company it's highly likely. This is implemented so code is easily reusable across assignments. So if you have something more complex then you dont have to duplicate work, you just have to tweak a bit and move the code.
What is Object Oriented Programming (OOP)? - What OOP is NOT
Read that too. It's about php but applies to most languages.
^ and you were making fun of me for being skinny, nerd. lol
do you really want to go there james? i can make you feel really bad about yourself.
uhhh ohhh here comes another live streaming internet suicide... Hide the pills!
Code:
Code:
Code:
final=func( var );
Code:
final=func( var );
Will be this:
Code:
msg="your text";
result=func( var );
final=msg + result;
Thanks. I think I get most of that, but I might have to read through it a couple more times. This class is online, so my only examples are from the book, so that's the reason I've formatted it this way. Do you think this is something that would likely be covered later for some reason, or maybe a crappy book/author?
hey sticks why you calling him a nerd? lmao jk
lol
I'm just fuckin around man. I don't know what you'd possibly say, but in the end nothing you could say would affect me at all.
Dustin: how old is the book you're taking examples from? Have you searched for different authors on the subject to possibly get a different point of view or way of writing the code?
this is like exactly the same stuff i was doing in my intro to java programming class a few quarters ago. i did real well while in the class but i feel like now i would be unable to even type up a basic program to save my life lol.
