HELP! Where does this connect to?
gunsnbam
I am so close to starting up my first car for the first time, but I can not find the connection for this anywhere. It it coming from the bottom of my ECU, there is another going up into the dash but this one is loose. I dont know how it came unplugged or what it is. Please help!
1 More question. Its a 1995 Civic ex with a 1996 b18b engine. Can I use the ls ac unit with the ls ac bracket? Or is getting a del sol vtec ac bracket and using the stock ac unit the only option?
if you dont have and ece mods(hondata. etc) then i would say its the dash harness connector
Where would it plugg up to...the engine runs and I have driven it a little bit, but now that I am having a to time the engine I can not get the timing light to come on...nor will the CEL light up when I turn the key. (it should come on for 2 secs and then go off)...would this be part of the problem? no i do not have hondata or anything like that.
pull back the carpet and everything else around there and just look around but it should be right around the heater box,
